Replace blank values from Confluence from Jira query
Jason Dyke
I am using table transformer to display results from a JIRA query. I was wondering if there is a way to replace the empty fields with text that actually says "Empty"?
I had tried something like this without success
Is there a way to replace the blank values with a different value?
6 votes
Katerina Kovriga _Stiltsoft_
August 16, 2022
Hi @Jason Dyke ,
You may try the following SQL query:
SELECT
CASE WHEN 'Col A' IS NULL
THEN "Empty"
ELSE 'Col A'
END
AS 'Col A'
FROM T*
Here 'Col A' is the name of your column where you want to replace empty cells with the word "Empty".
Hope it helps.
Jason Dyke
Perfect! Thanks for the help.
Like • Katerina Kovriga _Stiltsoft_ likes this
Learn more
