Restore specific spaces/projects
Mark Wiesenthal January 16, 2023
Hi everyone,
is it possible to restore specific Confluence spaces/Jira projects using the Admin console?
Best regards,
Mark
Fabio Racobaldo _Catworkx_
Hi @Mark Wiesenthal ,
Here some useful information about restore :
Hope this helps,
Fabio
Hi @Fabio Racobaldo _Catworkx_ ,
sorry, my question is a bit unspecific. If I do a backup of a specific space/project and e.g. delete the space, is it then possible to restore this space/project using the Admin console?
deleted items are not recoverable. You can try to restore them just from a backup (if you have it)
Fabio
Thanks for your answer. If I did a backup before, do I have to restore the whole instance from the backup or can I also do it whith one space?
Mark
If you have a backup, you can restore a single space using the following approach https://support.atlassian.com/confluence-cloud/docs/import-a-confluence-cloud-space/
Fabio
