Running javascript IFTTT
Matěj Mazák May 31, 2024
I am trying to create a Javascript automation in Confiforms and honestly don't know what I'm doing wrong.
I have two fields in my form:
  • Vote - which is a space delimited list of usernames
  • Winner - which is empty userpicker field and should be filled by one random username from Vote field
This is the IFTTT rule with the javascript I'm trying to run:
Now it could be that the javascript is wrong, I am not that strong in programming or that I am just parsing the values wrong way.
Alex Medved _ConfiForms_
Hi @Matěj Mazák
If you want to modify field values in UI with your custom Javascript then consider doing it via https://wiki.vertuna.com/display/CONFIFORMS/ConfiForms+Field+Definition+Rules#ConfiFormsFieldDefinitionRules-RuncustomJavaScript
Alex
Matěj Mazák March 11, 2025
Hi @Alex Medved _ConfiForms_
I've been looking into this again and in this example: Using ConfiForms Field Definition rules with JavaScript action to get and set field values
you are using a HTML macro to hold the custom JavaScript.
Where have you gotten this macro? Is there some alternative that I can use?
Our confluence doesn't have that macro available.
Matej
Oh, my CISO is not gonna like that :D
Thank you for your response. We can close it now.
Help us plant more trees
