Script runner Listeners is not working
Rajat Krishnan July 28, 2025
Hello Community,
I am trying to automate one of the feature in my jira 8 datacenter environment
Objective:
Inherit parent task text(under description field) of its corresponding sub-task description along with some hard coded text
Listeners:
  • Events: Issue Created
  • Server Side Code:
import com.atlassian.jira.bc.issue.IssueService
def issue = event.issue
if (!issue.issueType?.subTask) {
    return
def parentIssue = issue.parentObject
if (!parentIssue) {
    return
def parentDesc = parentIssue.description ?: "<No description available>"
def finalDescription = """\
1.Sub Task description:
2.Acceptance criteria:
3.Storage location:
4.Description of mother task:
${parentDesc}
// Run asynchronously so Jira finishes its own processing
Thread.start {
    sleep(4000) // wait 4 seconds for Jira's copy process
    def issueService = ComponentAccessor.getIssueService()
    def currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
    def issueInputParameters = issueService.newIssueInputParameters()
    issueInputParameters.setSkipScreenCheck(true)
    issueInputParameters.setDescription(finalDescription)
    def validationResult = issueService.validateUpdate(currentUser, issue.id, issueInputParameters)
    if (validationResult.isValid()) {
        issueService.update(currentUser, validationResult, EventDispatchOption.ISSUE_UPDATED, false)
    } else {
        log.warn("Description update failed: ${validationResult.errorCollection}")
Excepted Output:
While creation of sub-task, description field of sub-task shall contain
  • Hard coded text i.e.
    • 1.Sub Task description:
      3.Storage location:
  • Inherited text from Parent task i.e.
    • ${parentDesc}
Actual Output:
While creation of sub-task, description field is filled with parent description and not the hard coded text
Can someone please let me know what is going wrong?
Thank you
4 votes
Valerie Knapp
Hi @Rajat Krishnan , thanks for your post.
First of all, I always recommend to people to have a look at the sample scripts that are provided for this kind of thing, like this one for example, https://www.scriptrunnerhq.com/help/example-scripts/copy-linked-issue-value-onPrem , to not have to start from scratch.
Then, if you have used a sample script to start from and are still having trouble, I would open a ticket to Adaptavist, because this is a paid app and they provide support for this kind of thing - https://marketplace.atlassian.com/apps/6820/scriptrunner-for-jira?hosting=datacenter&tab=support
Have you already tried this?
I hope this helps you.
Best wishes
Rajat Krishnan July 30, 2025
@Valerie Knapp, thanks for sharing this information, yes i knew about this site https://www.scriptrunnerhq.com/help/example-scripts/copy-linked-issue-value-onPrem
but didn't contacted vendor directly as i thought maybe someone in community have already tried what i am trying to do, but yes i think its better to connect with vendor directly
Once again thanks for sharing details
Rajat K
