×The table-plus macro recently became payware and from what I've seen, most users are just using because it offered dynamic rearranging of row values by column. This is already offered by the HTML table so I'd like to change all instances of the table-plus macro to the HTML table macro. But I see no way of actually doing that, since it seem I cannot do a search for pages in use that have that macro in use somewhere. So I have to wait until the users complain that their table doesn't work and give me a link to the page.
Is it possible to search for all instances of the macro in use via some SQL query?
Thanks for this. just what was needed!
Another option is to disable the table-plus macro and add a user-macro of the same name that just shows the body-content. You also need to check for csv macro use.
