Set mandatory field when creating Jira issue from Confluence page
Yaniv L
Working with JIRA/Confluence on Data Center.
Our users can open an issue from Jira or from Confluence.
I set a mandatory (custom) filed on Jira.
How can I define that the same field will be mandatory when creating the same issue type from Confluence?
Yaniv L
@Tansu Akdeniz I did it via Admin - Behaviors
Tansu Akdeniz
November 30, 2022 edited
Could you make the field required from Project Settings -> Fields page via field configuration scheme? Then retry creating from Confluence? Because behavior script only works when you load the create/edit screen pop-ups.
Tansu Akdeniz
Hi @Yaniv L
How did you make "System" field required? Workflow validation or field configuration scheme?
