Showing issue status from jira in a confiform field
ebrahim rezaian December 26, 2021
Hello my friends
i had used "cwx publish issue (deprecated)" post function in my create issue transaction. in template of this postfunction i have a confiform form.
i want to  show status of linked issue (from jira) in a field of confiform (in confluence). in this way i can use "ConfiForms Field Definition Rules" to restrict edition of form in some issue statue (from jira).
can you help me in that way?
Alex Medved _ConfiForms_
Hi
There is no need to over complicate things with additional macros (rules or additional ConfiForms fields) and so on...
if you have a Jira issue field (type) in ConfiForms then you can easily access any property/field of the linked Jira issue https://wiki.vertuna.com/display/CONFIFORMS/Accessing+Jira+issue+fields+directly+from+ConfiForms+using+Jira+issue+field
Alex
Ronny Zimmermann
April 15, 2024
Hi Alex & everyone else,
I searched everywhere and didn't find anything. Is there a way to show two (or more) Jira issue field contents in one confiform "cell" (via the "Field name" definition )? Specifically, two of a different kind. And more specifically, the following svg and text?
Priority icon (svg):
JIRAISSUE.fields.priority.iconUrl.prepend(<img width="16px" src=").append("/>).renderAsHtml
Priority name (txt):
JIRAISSUE.fields.priority.name
I want them to be shown like this in one "cell" of the resulting confiform table:
Critical
Both are "children" of priority which looks like this:
{"name":"Critical","self":"https://jira.<...>/rest/api/2/priority/2","iconUrl":"https://jira.<...>/images/icons/priorities/critical.svg","id":"2"}
Thanks in advance for your response,
Ronny
Hi Ronny
Try the following
JIRAISSUE.fields.priority.name.prepend([entry.JIRAISSUE.fields.priority.iconUrl.prepend(<img width="16px" src=").append("/> )]).renderAsHtml)
Alex
Like Ronny Zimmermann likes this
Ronny Zimmermann
April 15, 2024
Hi Alex,
thanks so much. That did the trick!
Best,
Ronny
