Single User Picker > ConfiForms Create Jira Issue (Customfield)
GAVIN Benn
I'm trying to use the Single User Picker in ConfiForm to select a User and then push that information into Jira for a custom field that is a User Picker in Jira.
The information that ConfiForm generates is a user ID # 5d76ed45ae19790db93fa1b1 and Jira doesn't seem to be matching that up in the customfield.
  • Custom field 'Owner' is created using the same User Picker for Assignee / Reporter default fields.
  • Custom field 'Owner' is on the Jira Create Issue screen for the issue type 'Epic'
  • I've tried using "id" and "key"
  • I've tested using the same code for default reporter = current user replacing reporter with customfield_12103 and it adds in the current user correctly.
    • "reporter": { "id": "[entry._user]" },
  • I have also searched other Jira support boards and couldn't find the same issue replicated and solved.
JSON:
"customfield_12103": {"key": "[entry.owner.escapeJSON]"},
Alex Medved _ConfiForms_
As far as I know (but Atlassian should not it better) the user field in JSON mapping should be mapped as follows:
"customfield_12103": {"id": "[entry.owner]"},
Something like 5d76ed45ae19790db93fa1b1 is the account id in cloud that identifies the user
Assuming the user has access in your Jira instance and the project, it should work
Alex
GAVIN Benn
Looks like that has worked.  So as long as the user has access to the Project and the Instance this will be okay.  Is there an existing thread on what I can do when someone doesn't have these things instead of it generated an error / Null value?  Similarly the field for Reporter would have the same requirements as it's setup as 'reporter = current user'.
"customfield_12103": {"id": "[entry.owner.escapeJSON]"},
The user is an Admin to the Project and a user in the Jira instance also.
ConfiForms does not know if the user account you are passing as an argument into some field in Jira has access to your Jira instance or not.
Unless there is some kind of a security group that tells that, if you have it configured that way
In this case the virtual function https://wiki.vertuna.com/spaces/CONFIFORMS/pages/2359385/Virtual+functions to check if the user belongs to a group can be used (userInSecurityGroup)
atlassian, team ’25 europe guide, teamwork collection, atlassian events, conference guide, team culture, collaboration tools, ai in teamwork, atlassian learning, event schedule, keynote previews, community events
Must attend events for Team Europe '25!
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
