Skip dropdown in ConfiForms smart classifier when dropdown has no values
Mandy Butschke-Lange November 27, 2023
In my form (f2) I use the field type "smart classifier" and there I use the following three fields from my references form (f1):
  • field1
  • field2
  • field3
In some cases field2 has no values in f1, because field2 is not required. In such cases the smart classifier in f2 should show the dropodown for field3 directly after a value from field1 has been selected. How can I achieve this behaviour?
Thanks in advance for help.
Alex Medved _ConfiForms_
Hi @Mandy Butschke-Lange
That is not quite possible, as the smart classifier field works on the reducing the options in the order given
So, for the field1 then looking for sub values in the field2 and then leaving only the field3 values matching the other 2 fields selected before
Alex
The workaround would be is to set some default value for the field2, so it will be auto-selected and cascaded to field3 in the dependent dropdowns in a smart classifier
