Dear community, whenever I open the courses, the message 'Welcome to Smart Courses Editor' appears each time I open them. Is it possible to turn this off? Thank you in advance!
Hello Anne-Sophie,
This is Hassen from the support team at Creativas, the Smart Courses for Confluence vendor.
If you're using Smart Courses for Confluence, you can skip these onboarding messages by disabling the following feature in the Smart Courses global configuration.
This feature will disable the onboarding for all users and it is available from Smart Courses Data Center version 8.2.0 onwards.
If you have any additional questions, please reach out to our support team through our portal.
Best regards,
Hassen
Can you provide more context, Confluence has by default no "Smart Courses"
Is a 3rd party app used in you instance, I do suspect that there is.
And I think this one: smart-courses-for-confluence-lms
Reach out to the vendor and rely them with this issue at their support. They are the builder of the 3rd party app and control the working.
