Hi
I want to set up a Space automation rule around a status
The requirements is:
When a pages status changes to 'Ready for Publishing' create a task in a Jira project and populate some of the fields
The content statuses are enabled
I have selected a specific space in the rule scope
I am at the first stage - Trigger > page status changed but there are no options for the page status?
The page status of 'Ready for Publishing' is just one status - it doesn't change there is no requirement to have the page in progress or under review for example - when the work is done the 'Ready for Publishing' status will be selected that will prompt the automation rule
Could it be that i'm only using one status therefore it isn't changing?
Sherry
Hereby ignored ;)
Hi - so I managed to figure it out :-)
I would like to add the Confluence Page link in to the Jira Ticket - not as a hyperlink in to the Description or other field but use the Confluence Link functionality
Is this possible?
