Space not appearing for Meetical
Liz Humphrey June 20, 2024
I've tried everything I can think of including adjusting permissions and no matter what I do, a space I want to add meetical onto a page for is not appearing as an option.
Barbara Szczesniak
June 21, 2024
@Liz Humphrey Welcome to the Atlassian Community.
I'm not familiar with the Meetical app, but I have a few thoughts:
  • Are you trying to insert it in the space you are currently in? Some macros have a way to indicate the current space, rather than selecting it through search.
  • If you keep typing to the plus sign, rather than stopping at "build," does the space come up?
  • Maybe it has an issue with the plus sign in the space name?
Liz Humphrey June 21, 2024
I thought about the plus sign too so I changed it to remove that, but no luck. I've tried it from both the meetical app in Confluence and from the Meetical extension in the Google calendar, nothing comes up if I keep typing.
Shawn Doyle - ReleaseTEAM
Are the spaces that are showing up from the Confluence site you are using? Is there a chance it's looking at a different Confluence site?
No, this is the only confluence site. All other spaces in there are appearing, just not this one.
Nicolas Grossi
Banned
June 20, 2024
@Liz Humphrey Welcome as you have an stadard license you might contact support.atlassia.com
Nicolas
I tried that and got this message, so came here.Screenshot 2024-06-20 at 12.16.25 PM.png
Like • Nicolas Grossi likes this
