Support for Balsamiq or Gliffy for Confluence & Jira OnDemand
mlehane September 10, 2012
We are using Jira & Confluence OnDemand
Q1. We would like to start using Balsamiq or Gliffy or possibly both with out OnDemand apps, can we do this?
Q2. Do we need to buy seperate add-on licenses for both Confluence & Jira OnDemand?
JohnA
September 10, 2012
Hi there,
You can use both Gliffy and Balsamiq on the OnDemand platform, (they are some of the few bundled plugins), and you will need to purchase separate licenses for each application, so one each for Confluence and JIRA.
All the best,
John
Here is the answer to the Balsamiq side of the question:
http://support.balsamiq.com/customer/portal/articles/223421
Harry Chan
September 10, 2012
Yes and yes. Refer to https://confluence.atlassian.com/display/AOD/Atlassian+OnDemand+Plugin+Policy for more information. Gliffy's license can be purchased as part of OnDemand.
Learn more
