I'm trying to change the default space permissions to remove admin etc. from the confluence users group. I'm getting the error below, and the support link doesn't seem to work.
A system error has occurred — our apologies!
For immediate troubleshooting, consult our knowledge base for a solution.
If you would like to receive support from Atlassian's support team, ask your Confluence administrator to create a support issue on Atlassian's support system with the following information:
Your Confluence administrator can use the support request form to create a support ticket which will include this information.
We will respond as promptly as possible.
Thank you!
Got this answer from support:
As I checked, I was able to replicate the issue ; and this is being reproducible on our test instances as well.
Upon digging more, I learned that the issue we are facing is actually affected by a bug reported to our developer team to review here:
As this affects all of us, I also want to point that we have an internal incident and our dev team are currently working on a fix at this moment.
So, although you will see in the public page its Priority set to 'Medium' only, I can guarantee it wont take long to get this resolved.
site admin here, too. Having the same issue.
