Table of contents macro links not working in view mode. But works in edit mode
Jaganathan.P
November 11, 2024 edited
This below confluence page table of contents macro links not working in view mode. During edit mode the navigation works.
Tired multiple approaches like , changing the heading format and other but it does not help.
Please help on this . This affects our business.
Kristian Klima
Hi @Jaganathan.P and welcome to the Community.
A side note first - this is the public forum, so whatever you post can be seen by anyone on the internet. And while your link requires login, it's not something I'd necessarily share :)
Advice here is to share screenshots with sensitive bits blurred/covered.
Now, to the actual issue. I could not replicate the behavior - and I've chosen a page with all sorts of macros and 3rd party plugins to test it.
So I'd investigate the following:
  • Does this affect any page with a TOC macro?
  • Does this happen in any browser?
  • Does it happen when you open Confluence in the browser's Private mode and log in?
  • Does it happen when you disable browser extensions / plug-ins?
  • Clearing the cache might help too.
Barbara Szczesniak
November 12, 2024
One additional thought, have you published the page?
Do you see the links in View mode, but they just don't work or are they not visible on the page?
Generally, only published content shows in View mode.
Like • Kristian Klima likes this
Kristian Klima
Good point @Barbara Szczesniak :)
Kristian Klima
Actually, @Jaganathan.P , I was able to replicate the issue - by placing a heading inside a macro.
Just wanted to share the info as it might put you on the solution path.
Like • 2 people like this
Jaganathan.P
November 13, 2024
Thanks for your response @Kristian Klima .
Yes, All the heading contents were under "Numbered Headings" Macro. After removing the Numbered heading macro, the issue is fixed.
Laura Blom
I'm having the same problem. My ToC links aren't working unless I'm in Edit mode.
I use Headings in my page, but I don't know what the "Numbered Headings" macro is. Of course my headings are h tags, otherwise, they wouldn't show up in the Table of Contents.
- Yes, this is happening in other pages with ToC.
- This is happening in Chrome and Firefox.
- It happens in Incognito mode on fresh cookies.
I had emojis in my headers, so I removed them, but that didn't make a difference.
I've been using Confluence forever and this is a new problem. It looks like a new bug was introduced when I enabled the new navigation a week or so ago.
Like • 5 people like this
Lasse Kaiser
May 1, 2025
Having the same problem and being inspired by Laura Blom's post, I turned off the "New navigation" feature for myself and now it works as expected, so it definitely has to do with this beta feature.
Then I turned on "New navigation" again and refreshed the page, expecting the link to become inactive, but it still worked. Good news - especially if it also works tomorrow ;-).
Like • Laura Blom likes this
Rick Westbrock
I am having the same problem for a couple of weeks now but had forgotten that I had only enabled New Navigation for myself. Disabling then re-enabling that fixed the problem for me too so kudos to @Laura Blom for mentioning that.
Like • 3 people like this
Laura Blom
Great thinking Lasse and Rick! Thanks, it worked for me too.
Like • Lasse Kaiser likes this
glen.oneil
May 14, 2025
I found if I cut & paste directly from Word, not as plain text, trying to retain some of the 'headings' formatting, I got this error.  If I pasted as plain text without any formatting, then cleaned up the 'headings' it worked.  Just something to try for others experiencing this issue.
Kristian Klima
Transporting formatting from Word is, more often than not, source of pain.
A workaround is using Google Docs as an in-between in the copy-pasting process between Word and Confluence.
You win some, you lose some but the end result tends to be better.
See inside
