When I am going to export PDF ToC is not working. I want numbers in this list: like 1, 1.1. Can anyone help?
Hi Rupan - Welcome to the Atlassian Community!
I agree with @Kristian Klima - I am able to do it with no problem.
In the TOC macro's setting, I checked the Include section numbers option and my PDF came out with section numbers.
Unless you are referring to numbering of the navigation tree (the left hand side section in Confluence).
I can only recommend that you check out Scroll PDF Exporter by K15t which I believe does support the feature (and also sorts out pretty much any headache the stock exporter creates while including a ton of customization options).
