×I'm following this doc https://confluence.atlassian.com/bitbucket/deploy-to-amazon-ecs-892623902.html to set up a pipeline to deploy to the ECS cluster.
This doc is using a custom task def JSON file and using the same for the deployment after updating the image name.
Am I required to copy the complete task definition JSON and put that in my repository? My task definition has lots of environment variables in it. I do not want to expose them by putting it in the repository.
Or, the task definition template will update the default task definition and create a new revision. (not overwrite)
How can I use the predefined tasks instead of using the JSON file? Also, where can I find more doc about the pipe.
atlassian/aws-ecs-deploy
take your task-definition.json, encode it using base64, and copy the base64 into Deployment Variable in your repository.
Then add this step:
echo $TASK_DEFINITION_base64 | base64 -d > task-definition.json
