×I'm having some issues trying to add a Jira 2d Report of type Pie Chart to a Confluence page.
Step #1: I have a confluence page where I want to add the report:
Step #2: I select the Jira widget:
Step #3: I configure the pie chart:
I believe that when I select the display option for Status, I get an error in the Javascript console. Here's the error:
I'm not sure if that's related. Once I click Insert to insert the new report on the my Confluence page, nothing happens. The page is not updated with any new content. Any suggestions?
Hi Bret,
Thank you for contacting us about this.
I suspect it could be related to CONFCLOUD-65519 (When editing a Jira Gadget macro, the internal Save button is not shown), but I would need further information on that.
Let me know how the tests work, and we can proceed from there.
Shannon
Thank you, Shannon. Is there a way to control the format of the text in the diagram?
Hi Christine,
It's not possible, unfortunately, since with Confluence Cloud modifying the theme including fonts is a restricted functionality.
See Functional Differences in Confluence Cloud for more information. Let me know if you have any questions about that.
Shannon
@Shannon S we're having the exact same issue with Confluence and Jira Cloud. The insert button in the 'insert jira chart' window is visible and clickable but even that the preview shows the the chart / pie it doesn't show on the page. We tested from different browsers and different computers and no one was able to add a Jira macro to Confluence.
Hi @Ben Sharir,
Welcome to Atlassian Community! It's nice to meet you.
Are you encountering the same error that @Bret Truchan was encountering in your Developer Tools console?
Error: undefined missing confluence/api/navigator-context
If so, I think this issue might be related to the following bug:
However, the workaround stated there is to use the Jira chart macro, which you're both already using. There's a comment internally about how it may be related to another issue with gadgets, but it appears that issue might be already resolved.
I'm going to try and see what I can find out about this and I'll let you know if I hear anything.
Shannon
@Shannon S yes, we're encountering the same error that @Bret Truchan is encountering in the developer console (see screenshot). You're right about the workaround stated in CONFCLOUD-65999 is to use the Jira Macros that we're both already using. I'm not sure about the internal comment with this issue being related to gadgets as even if it's resolved, we're still unable to use macros in Confluence as of now. Your help is appreciated.
Hello Ben,
Thank you so much for providing those details. I'm trying to get in touch now with the development team lead to see what we should be doing; if the bug I sent is in fact the same cause as this one, or if this is a new issue entirely.
I'll report back when I have any details.
Shannon
Good morning!
I spoke with the team, and it appears that the bug is a duplicate of this case:
This one is on its way to being fixed, and is being tested in staging at this time. I'll let you know once the release is confirmed, and then we can see if this fixes the issue you all are having.
There's a workaround we can test now:
Instead of selecting the Jira Charts macro from the Jira issues macro menu, directly select the Jira Charts macro from the macro browser by selecting the View More option on the insert/+ dropdown.
Could you all give that a try and see if it works for your site?
Shannon
That's great, Ben! Thanks for confirming that.
I'll be watching the CONFCLOUD-67476 bug in the meantime, and I'll follow-up with you when it's resolved.
Shannon
