Using Page Properties via MCP
Regan Marshall
Has anyone found a way to get Page Properties to work via MCP? I'm hoping I can get Claude to create and update a Page Properties table to create some structured content.
When I update existing, it breaks the page properties and just gives me the table. I can't get it to create one from scratch either.
It doesn't look like its in the toolset but I was hoping for a work around.
Vishalakshi Narayana Swamy
June 19, 2025
Hi @Regan Marshall
Welcome to Atlassian community!
I understand that you are facing issues with using MCP to work on page properties.
I suggest you raise a request with our MCP team directly here https://customerfeedback.atlassian.net/servicedesk/customer/portal/1701 for better assistance on the issue.
Hope this helps!
Best Regards,
Vishalakshi Narayanaswamy
