Where is Product Access?
James N. April 8, 2024
In this article:
https://confluence.atlassian.com/confkb/how-to-grant-access-to-one-space-only-to-a-user-in-confluence-815244321.html
Under "Steps for Confluence Cloud", step 7 says:
"From the User management go to Product access > Product access."
Could some please tell me where to find "Product Access".   But use really graphic simple steps to explain it please.  I have worn out Google trying to find it, and I am just not having any luck.
2 accepted
Mikael Sandberg
It depends on if you are using managed accounts or not. If you are using managed accounts, then you will find the Product access if you go to admin.atlassian.com and click on Products > Users > Product access
You will then see something like this where you can add groups that should have access to products
If you are not using managed users then you can get to it if you click on Directory in admin.atlassian.com, select the group and from here you can add products that the group should have access to
Kian Stack Mumo Systems
@James N_
Go to admin.atlassian.com -> Click on Products in the upper toolbar.
In the middle of the page, you should see Confluence. Click on the Manage Product link.
In there, you should be able to add the group you created in the previous steps listed on that page.
