My Whiteboards today showed me a banner which says:
"Whiteboard features and creation will become limited on some plans starting February 28, 2024. See what's changing and how to prepare"
With a link to this page: https://www.atlassian.com/software/confluence/whiteboards
I can't find any details here on what is changing from my beta access for the plan we are currently on. Can you provide some clarity on which Whiteboard Features will be available for which Confluence plans.
So standard and free plans have the same active board limit?
It's getting really hard to see why we should continue to pay Standard fees for features that are not that different from a Free plan.
Hi @Hannah Meneley @Clark Everson
Sorry about that.
We've updated the link to direct you to this page.
Let me know if you have any further questions.
I do have a few follow up questions based on this.
Hi @Hannah Meneley ,
To answer your first two questions, you will only be able to have 3 'active' whiteboards at a time - i.e. create 3 boards. If you go to create a 4th board, the oldest created board of yours will become 'inactive' i.e. view-only, so you cannot edit that whiteboard anymore.
However - you may still collaborate on as many boards as you like (provided they are also active boards) - the 3 board limit only applies to boards YOU create.
To answer your third question, you cannot switch boards from active to inactive unless you go and delete one of your 3 active boards.
The above link references smart connectors, see here for more detail on these. This type of connector will be available in Premium. It does not refer to basic lines.
Hope this helps!
@Christina Ristevski can you also switch boards to inactive when they are archived or does it need to be deleted?
Also, does restoring a whiteboard bring it back to the active dashboards list with the oldest board now becoming inactive?
Hey @Randi Cyr apologies for the late response.
Once a whiteboard is inactive, it cant be 'reactivated', even by archiving/deleting and bringing it back.
If however, you archive an active board, when you un-archive that board it will bring it to an unset state, whereby you will be able to 'exchange' a board to bring it back to active.
On unarchive and restore
For context the "unset" state is when a pop up appears that provides a 'call to action' to the user to swap whiteboards or deactivate the current whiteboard.
Let me know if this helps.
Cheers!
Hi Hannah,
Reviewing community it has not been announced yet in regards to what will be limited.
I would recommend following: https://community.atlassian.com/t5/Confluence/ct-p/confluence and when they post any announcements they show up there.
The Whiteboard feature was a new Beta Feature so date announcements tend to mean they are being moved out of Beta, and usually this leads to limitations depending on plan. Limitations could be anywhere from who has access, a separate license or total number allowed in an instance.
I hope this helps!
Best,
Clark
Hi Clark,
I was hopeful that @Christina Ristevski would be able to provide more details. My team and I have been using the Beta for several months now and would like to understand how these limitations will impact us.
Your response here is what I have gathered reviewing the community and link as well.
Meet the engineers who are making the Confluence magic happen at Atlassian ✨
RSVP now!
