Whiteboard keeps freezing 'code hung' error in Chrome
Tad Blake-Weber June 3, 2025
Hi Confluence White Boards may just be having an off day, but 5 times within 5 minutes my whiteboard froze and Chrome forced me to quit using the page. I'm getting an 'Aw Snap Code hung' error. Is this happening to anyone else?
3 accepted
3 votes
Nikola Perisic
Welcome @Tad Blake-Weber
Piyush Annadate _ACE Pune_
Hello @Tad Blake-Weber ,
Welcome to the Community !
Eventually, that did happened to me on other browse ( a chrome based browser) - All you need to do is: Open your site -> Right click -> Inspect OR Developer Option -> Application -> Storage -> Clear Site data including third party data as well.
If this doesn't work as well; do the above process mentioned by @Nikola Perisic & @Marc - Devoteam
Do check for your developer option console logs about the issue ; that sometimes help about the actual issue.
If that's for many of users - check your browser versions and try to upgrade/downgrade; different browsers - if still an issue- then contact support Atlassian team to investigate.
Marc - Devoteam
June 3, 2025
Hi @Tad Blake-Weber
In addition to @Nikola Perisic disable any browser extensions.
ENTERPRISE
