Widget macro not working for Flickr or Twitter
Kari Obrist August 6, 2019
I can not get the widget macro to work for Flickr or Twitter. All I get is the little gear icon with the URL, but I don't get any feed information. I'm on Confluence Cloud and have tried on a few different browsers.
Any ideas
Prem Chudzinski [extensi]
You can use this app to integrate Twitter
https://marketplace.atlassian.com/apps/1216687/twitter-connector-for-confluence
The widget won't work.
Cheers
Przemyslaw
SMS
August 8, 2019
Hello Kari,
Thank you for contacting us about this.
I've seen the issue with Twitter in the past when they had deprecated the Twitter 4.0 API, and I imagine this is something similar. I was able to find a bug ticket for Twitter in Confluence Cloud, and the bug for Flickr in Confluence Server. I've created a Cloud version of the same bug below. Please click This affects my team and you will automatically receive updates in the future.
  • CONFCLOUD-29639 Twitter feeds have stopped working in the Widget Connector
  • CONFCLOUD-67432 Widget Connector Macro no longer working with Flickr URLs
As a workaround, users are using an HTML macro to directly embed the code from Twitter and Flickr. As you're on Confluence Cloud, you can try the same with 3rd party add-on  HTML Macro for Confluence Cloud, since the HTML Macro of Confluence Server isn't available for Cloud.
Let me know if you have any questions.
Shannon
Kari Obrist August 9, 2019
I don't think this is a great answer -- the solution is that I have to pay even more for a 3rd party add-on to use a feature that should come as part of my Atlassian subscription?
SMS
August 14, 2019
Hello Kari,
Yes, unfortunately, you will need to use the 3rd party add-on as a workaround. This issue is due to Twitter changing something on their end which caused the feature to stop working. This is likely the same with Flickr as I know they've been going through a lot of changes recently.
I would encourage you to subscribe to the tickets I sent, so you can be alerted as soon as the issue is fixed.
Thank you for your understanding.
Shannon
Connie McCutcheon
September 11, 2019
Not able to click "this affects my team" - don't see it anywhere.  That said ... this bug ... in fact does in fact affect my team.
SMS
September 12, 2019
@Connie McCutcheon,
Welcome to Atlassian Community, and thank you for following up.
The This affects my team link is available at the top-right of the bug:
I can confirm that for both cases, it's still possible to vote on them as they haven't been closed. If the link appears in grey, then it means you are not currently logged in. Please login and you will be able to vote.
Let me know if you have any trouble.
Shannon
