Zephyr Test - Test Exectuion fields into "Insert Jira Issue/Filter" macro
Peter Augustinak March 5, 2020 edited
Hello, is there any possibility to add some fields of Zephyr Test into Jira Issue/Filter macro?
I wanna have this list of Zephyr Test  as it is in the picture, but I want to read in this list also in what "Version" and with what "Result" it was tested - so fields from the Test Execution part.
Currently I'm not able to use this fields anyhow.
Thanks a lot for your answer.
https://i.imgur.com/tEYBnZv.png
https://i.imgur.com/lMZJ4qg.png
Fabian Lim
Hi @Peter Augustinak
I don't this is possible out of the box. I suggest you try using eazybi which has integrations with zephyr.
