I am developing an atlassian-connect Dynamic Content Module macro for Confluence cloud. I want to be able to configure the parameters for the plugin, however the non-string type parameters do not seem to be set in the url.
For example in the atlassian-connect.json below "htmlAttachment", "frameborder", and "scrolling" parameters are not being injected into the "url" ("frameborder" and "scrolling" can be set through the config page for the macro). Also, the HTML attachment does not appear to pick-up the attachments on the page.
"modules": {
"dynamicContentMacros": [
"url": "/foo?page={content.id}&space={space.id}&htmlAttachment={htmlAttachment}&scrolling={scrolling}&frameborder={frameborder}&width={width}&height={height}",
"parameters": [
"identifier": "htmlAttachment",
"name": {
"value": "HTML Attachment"
"description": {
"value": "The HTML file to embed"
"type": "attachment",
"defaultValue" : "",
"required": false,
"multiple": false,
"hidden": false
"identifier": "width",
"name": {
"value": "Width"
"type": "string",
"required": false,
"multiple": false,
"hidden": false
"identifier": "height",
"name": {
"value": "Height"
"type": "string",
"required": false,
"multiple": false,
"hidden": false
"identifier": "scrolling",
"name": {
"value": "Scrollling"
"description": {
"value": "Choose if scrolling should be enabled"
"type": "ENUM",
"required": true,
"multiple": false,
"defaultValue": "no",
"values": [
"yes",
"no",
"auto"
"hidden": false
"identifier": "frameborder",
"name": {
"value": "Frameborder"
"description": {
"value": "Surround IFrame with a border"
"type": "boolean",
"required": true,
"multiple": false,
"hidden": false
any thoughts would be appreciated.
Andrew
Hello @Andrew Tyson !
As I understand, parameters are not passed correctly. You can find further instructions about Dynamic Content macros here:
However, I believe that our sister community, the Developer Community can be the place where you will find your answer!
You can post your question here and other developers can help you out:
Let us hear from you!
Thanks Diego, I will post to the Developer Community.
Andrew
