Is it possible to automate the creation of a page to assign an status and apply a comala document workflow?
I'm using databases to store some relevant information and create a page using the templates. I want to apply the workflow when the page is published.
I'm working in confuence cloud version
Thanks a lot for your help!
I found a solution here: applying a workflow
In fact, I inversed the question and now I'm able to assign automatically the comala document workflow to pages using an specific tag.
So, using my database I centralize all my pages, the pages are created using a template and my template assigns an specific tag.
From the comala document workflow side, I created it as space workflow and I added in the propreties of the workflow the same tag created in the template. So, when I create a page and publish it, the workflow appears automatically in the first status defined (draft)...
