fixed width for tables
Stefan Wohnlich
December 26, 2024
Hello! I work on the DataCentre with the Legacy Editor. I can no longer set ‘fixed width’ in the table function. Does anyone have a solution for this? Thank you very much!
Dan Breyen
Hi @Stefan Wohnlich welcome to the community.  I don't know which version of Confluence DataCenter you are using.  I did a quick search on Atlassian's Jira site and found several issues related to the fixed width in tables.
Here's the query I used:
project = "Confluence Data Center" and text ~ "\"fixed width\"" and text ~ "table"
You may want to take a look yourself and see if there are any solutions to your issue there.
Hope that helps.
Shawn Doyle - ReleaseTEAM
Hi @Stefan Wohnlich
You may need to look at the add-ons to get more functionality with tables.
