The forward slash (/) shortcut isn't functioning in my Confluence space at work to bring up the menu, is there alternative methods available to access the same menu without relying on the forward slash?
@ola welcome to the community! I second @Shawn Doyle - ReleaseTEAM it's probably something with your browser. Do other people have the same issue? Does it happen to with another browser? I double checked, it is working on my system. I also using the menu item (the plus) in tool bar. I think that gets you to the same place.
Hope that helps.
Look to see if any browser plugins haven't overridden the /
An easy test is trying a different browser or with incognito mode.
