i need a tabs macro that supports the use of page properties report within the tab. suggestions?
Steven Eckstine August 20, 2025
when editing/configuring the content of each individual tab, i want to use the 'page properties report' macro or 'insert excerpts' macro to pull data from other pages
2 accepted
Abi Brown- Kolekti
Hi @Steven Eckstine
I am the customer success manager for Mosaic - content formatting macros and templates our top rated app has Tabs in our toolkit, which allows you to do this and we also have a standalone Tabs for confluence both will do and have a free 30 day trial and you also can reach out to me direct for any support you need abrown@kolekti.com
Happy testing!
KInd Regards
Abi
Steven Eckstine September 18, 2025
this worked. can include excerpts and page properties report.
would be really slick if you could embed tabs within tabs. think of a matrix view with multiple products on one set of tabs, but within each tab, a subset of tabs for different geographic regions (or flip the paradigm - region, and sub-tabs of products.
Abi Brown- Kolekti
Sadly Atlassian will not allow this level of nesting like we had in DC - the closest we can offer is adding advanced expand macro into  the tabs. e do keep asking though!
Abi
Melek Jebnoun_Vectors_
Hello Steven
My name is Melek and I'm the CPO of Vectors. We are the vendor behind Content Formatting Toolkit for Confluence
Our App offer Tab macro (Tabs Group and Tab Pane macros combined) that gives you the ability to include confluence macros in it. We do support Content Property report macro as you can see below:
Page in Edit Mode:
Several of our customers have implemented a similar case where each tab represents a product family card and under it they inject to Content Properties report macro to create a kind of comparison report.
I remain available for any additional support or you contact us on our Support Portal support.covectors.io
Hope it helps!
Steven Eckstine September 2, 2025
This seems like what I need. let me try the free version on marketplace
Like Melek Jebnoun_Vectors_ likes this
We remain available for any support needed :)
Steven Eckstine September 16, 2025
Tried the trial version.
Content Property only shows title, creator, and mod date of a page, which is inadequate for my purposes
I need Page Property Report for richer content found within a document
This macro does not seem to support PagePropertyReport or IncludeExcerpt
Hello Steven
Thanks for your feedback.
Is it possible what type of rich content you're using in your Page Property Report ? (Media, Macros ?)
In Cloud version, Tab Macro need to re-render page content and invoke Native formatting resources so it can be a simple Atlassian file invocation. This can be fixed very quickly by the team and pushed to Marketplace.
Do you mind to create a support ticket on our support system https://support.covectors.io/ this way we can identify the problem and fix it quickly in order for you to use the app :)
Many thanks
You can also contact us directly via our Intercom bubble when you edit the Tab group or the Tab Pane macro.
It's quicker than the support portal :)
Mia Tamm _Simpleasyty_
Hi @Steven Eckstine ,
That sounds like an interesting setup. Could you share a bit more about your use case? For example, are you trying to create a kind of dashboard where each tab shows a filtered set of page properties, or is it more about organizing different reports in one place?
I’m curious how you’d like the tabs + Page Properties Report to work together, it might help others suggest the best approach or alternatives.
— Mia Tamm from Simpleasyty
The former, each tab shows a filtered set of page properties
Like Mia Tamm _Simpleasyty_ likes this
Hi @Steven Eckstine — thanks for clarifying.
We’re actively working on a Simple Tables macro that can read Page Properties directly, so you won’t need the Page Properties Report macro to roll them up.
What this brings: you’ll be able to pull properties from many pages into one table and then use Simple Tables features (sorting, grouping, calculated columns, aggregations, exports, etc.) to turn those properties into decision-ready views—basically taking Page Properties to the next level.
About your “tabs with filtered sets” idea: today Simple Tables doesn’t have saved “views” yet. Once we ship Page Properties ingestion, we plan to focus on saved views/presets so each tab can show a filtered slice—exactly what you described.
Meanwhile (workarounds):
  • Use Page Properties Report per tab with different labels, or
  • Duplicate Simple Tables with different input subsets (not perfect, but can help for now).
If you can share your typical filters/columns, I’ll make sure we cover them in the design—and happy to loop you into early access when it’s ready.
— Mia Tamm
ENTERPRISE
