maven-confluence-plugin
Oleg Kalinin March 24, 2016
I need to install this plugin - https://github.com/bsorrentino/maven-confluence-plugin
Is it compatible with my instance? Atlassian Confluence 5.8.4
I can't find this plugin by searching (Add new plugin) and can't find the corresponding jar file to install.
Thanks for your help.
Oleg K
Oleg Kalinin March 25, 2016
Thanks, guys, for clarifying!
Robert Massaioli _Atlassian_
March 24, 2016
It does not look an Atlassian P2 plugin; it looks like a maven plugin. I think you are supposed to add this maven plugin to your maven configuration and then it will generate documentation and send it to a Confluence instance.
Alex Yasurek
March 24, 2016
Yes I agree. Seems to be a source code for a plugin you have to build yourself. You don't directly add this project to confluence.
