page not found
sina rahemi September 11, 2024
hi
Some pages give "page not found" error. It gives this error even with admin user.
I can find the page in the search and in the tree
This happened only to some pages and the rest of the pages in the same space can be seen without any problem
Within the Space permission, the admin user does not have access to the view. When I tick the view, it is not saved and it returns to the previous settings
in Inspect Permissions:
Rilwan Ahmed
Hi @sina rahemi ,
Admin does not mean user will have access to all pages/spaces.
Restrictions are added in space level and it can be in page level also. Page restrictions are inherited from parent pages. So go to space settings --> Permissions --> Restricted pages tab. Grant access to yourself.
Regarding space permission page not getting saved, try in different browsers like edge, mozilla etc
Vronik
September 11, 2024
Hi
It is probably influenced by the fact that there is an incident with Confluence at the moment.
https://status.atlassian.com/
Check often and when it is resolved, try again to see if it works correctly again.
Regards
Rilwan Ahmed
Hi @Vronik ,
https://status.atlassian.com/ is only for Atlassian cloud instances
Vronik
September 11, 2024
Hi
Sorry, I didn't realize that your option is DataCenter, anyway, you can always create a ticket to the support team
On this page you have an option to "report a problem"
https://confluence.status.atlassian.com/
