The spaces menu in the header has stopped working. No-one not even admins can access it. Any ideas? The only way to navigate to spaces is either by a known url or having admin rights to via the admin dashboard.
when you click on the menu this error appears in the console
image2016-1-14 21:30:5.png
please can you raise awareness with the cloud support? I don't even know where to start.
there are no other errors I can find.
Hi Nick,
Is there any visible error message in the UI? Do you know when this issue started and if it was after some upgrade performed by the cloud team?
It might be a good idea to check with the cloud support if this instance contains some error in the logs as well.
Rodrigo
