Is there a facility to put a rating scale in a confluence page? For example, have a table of movies and put a five star rating in one of the columns. Obviously I could put in pictures with a fixed rating. But I wanted to be able to offer a rating scale and have the reader able to select the rating. Again I can just say "enter 1 to 5", but a clickable star rating object or a slider would be better.
I'm looking for the same and Adaptavist looks great. Is there a similar add-on for a confluence cloud version? Thank you.
Such an add-on exists for Confluence Server: https://marketplace.atlassian.com/plugins/com.adaptavist.confluence.rate/server/overview
It is written by the add-on developer Adaptavist. You should contact them and ask them to make a server version of the add-on.
Clearly they have chosen not to do this despite the fact that the server products are going away.
Any other suggestions for implementing this feature in Confluence Cloud? I am frankly kind of surprised this feature doesn't exist.
I don't think there would be an easy way to do this without developing a custom add-on.
The easiest add-on would just give you a series of macros for 1 star, 2 start etc, however it would also be possible to create a macro that works like the colour picker on the Status macro.
James, Thanks for your help. As a regular user of Confluence I am always afraid that there are features or add ons which the power users know about but which I have not stumbled upon. I can stop looking now ![]()
No problem - its actually a great idea for a macro.
Did anything get created in this regard for Confluence Cloud0?
I'd like to create an "App Store" where apps are rated and can be downloaded from a Confluence page - but can't see anything like this.
@Fraser Macmillen- I just came across this one: https://marketplace.atlassian.com/apps/1220928/rate-me-for-confluence?tab=overview&hosting=cloud
