Hi to all,
simple question: when I use the @ to mention someoe, no @ does appear instead the "@"-shortcut turns the textstyle to size "title2". So I have to click on the @-button on top to use the @ sign to mention someone. In other applications the @ works totally fine.
Any ideas?
thx
Welcome to the Atlassian Community!!!
As I can see that you have mentioned a label for Confluence so
I would suggest you to go through this article
Or if the problem is not resolved I would request you to raise a ticket to Atlassian Support.
Mayur
Hi Mayur,
thanks for you answer. The case is exactly like described in your link, but the "Disable Autocomplete" option was not ticked. So it does not make any changes.
Cheers, Erich
Are other users are added to Confluence or that particular space where you want to tag them?
Also you can check editor preferences. If that is disabled, then it will turn off the mention ability.
Yes I have other users in the team and I can tag them by using the mouse and klicking on the @ sign. But when I use the "key way" to type an @, then the letter size changes to title2.
So it seems like this short cut is linked to change the text size instead of just type an @.
Cheers, Erich
Want to leave your mark on Confluence? One winner will have their whiteboard design added into Confluence for all users to access! This is your chance to showcase your creativity, help others, and gain recognition in the Confluence community.
Share your template today!Online forums and learning are now in one easy-to-use experience.
