confluence cluster issue
jameers January 2, 2018 edited
Thanks in advance
we hosted our confluence data center in aws. we followed all installation steps which mentioned https://confluence.atlassian.com/conf65/installing-confluence-data-center-939701973.html but when we start the node-1 it is coming up. but node2 throwing error(
HTTP Status 500 - com.atlassian.vcache.ExternalCacheException: Failed due to UNCLASSIFIED_FAILURE
when we restart node2 it is coming up and node1 throwing same error as above. Is there any modifications required in configuration files?
our infra:
ELB
2 EC2 instances
RDS-postgreSQL
EFS- nfs enable(shared home)
1 comment
Dave Theodore [Coyote Creek Consulting]
What happens if you restart the Confluence app on node 2? Occasionally, I've seen odd cases like this where the app starts up slowly and certain required components of the app timeout. This leads to a domino effect of other things not starting and odd errors.  If it is still behaving strangely after an app bounce, shut the app down and delete the Confluence application log and restart. This way you're starting with a clean log.  Post up the first few errors in the log and I think we should be able to help you sort this out.
jameers January 7, 2018 edited
Issue with both instances are not communicating each other due to network(telnet not happen). Now issue got resolved.
Thank you.
jameers January 14, 2018 edited
@Dave Theodore [Coyote Creek Consulting]
Please help this
when i login into the application with admin credentials , it is getting login and immediately getting logout.
No errors thrown in the atlassian-confluence.log. The following warning flashes quickly and user is redirected to the login page
Sounds like you have issues with your load balancer configuration. If I were a betting man, I would say your load balancer is probably not session sticky.
