Hi I am trying to send a file through restapi which it has special characters (I am using git , I commiited the file and tried to send through restapi), I am using below rest call, but its not anchoring or not generating the review link if the file contains any special characters,
Please let me know hpw to fix this issue
$headers = {"Accept" =>'application/xml', "Content-Type" => 'application/xml', "Authorization" =>'Basic '};
my $responseContent = $client->POST('/rest-service/reviews-v1/?FEAUTH='.$token, $file, $headers);
Dandu
its working now, I've added ![CDATA , its working now, thanks
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<addPatch>
<patch><![CDATA[
patchdiff here..
</patch>
<anchor>
<anchorPath>/</anchorPath>
<anchorRepository>$repo</anchorRepository>
<stripCount>2</stripCount>
</anchor>
</addPatch>
As you send the patch in XML format, some special characters must be encoded.
One page where these are described is http://en.wikipedia.org/wiki/List_of_XML_and_HTML_character_entity_references#Predefined_entities_in_XML
If you are using an "&" (ampersand) in your patch, then you need to replace it with "&" if you want to send it as XML.
I am doing diff of my file which it contains special characters, If I am parsing this text into restapi format , it is not working, it doesn't accept the special characters.
patchcontent
DIFF IS diff --git x.txt x.txt
index dec2cbe..d0c7fbe 100644
--- x.txt
+++ x.txt
@@ -1,2 +1,4 @@
test
test
+test
+test
diff --git y.txt y.txt
index 8164a18..a58ee72 100644
--- y.txt
+++ y.txt
@@ -1,2 +1,3 @@
test;
&del
+&del
I used this restapi call
<addPatch>
<patch>
patchcontent
</patch>
<anchor>
<anchorRepository>reponame</anchorRepository>
</anchor>
</addPatch>
