Checklist view automatically opens up when navigating to another view
Carmen Popp December 8, 2022 edited
I created a private individual checklist to test this feature. Since then every time when I navigate to another view (e.g. from Program board to Strategy tree) then the Checklist view on the bottom opens up automatically. I then need to close this view again manually. This is very annoying. Can I adjust this behavior via a specific setting?
It does not even disappear if 100% of the checklist is fullfilled.
I also do not know how to select the checklist I want to perform, if there is more than one checklist.
Thanks in advance :-)Screenshot 2022-12-08 132019.png
Tom O'Connor
December 8, 2022
When you hover over the checklist on the far right side there are some popup menus. My assumption is you need to resize your screen zoom so that you can see those options. Once you close the checklist, it should not appear as you navigate to other areas.  See below:
Carmen Popp December 9, 2022
Thanks a lot! I always used this arrow in the middle to hide it and then it came up again and again. Perfect.. close fixed it :-)
Like Tom O'Connor likes this
