Is it possible to present a roadmap in Jira Align at the Story level, showing dependencies, sprint timelines, and the developers assigned to each story?
Thank you!
You can view Story details in Roadmap however it is not same view as Epic or Feature level.
Steps: Go to Roadmap in Jira
Default dropdown is "Work" change it to "Program Increment" so that you can see Story details for that PI here Story means both Story and Task in Jira Align.
@liora Jira Align roadmaps are intended to be the strategic intent of an organization's planning. It is not meant to represent the planning the teams do. When using either of the Feature views in Roadmaps, you can see any stories that have been planned by sprint represented by boxes. And when you hover, you can see the stories and drill in from there.
The Program Board represents when the teams expect to finish their stories according to sprints. Dependencies are represented according to sprints as well. When hovering over the items on the Program Board, you can also see how objectives, features and dependencies are tied together.
Even though the stories aren't displayed on the Program Board, if you click on a feature, you can see all stories created by all teams and when they are expected to be completed. The person assigned to the story is not listed.
Hopefully this helps!
