Sign up Log in
Monitor and inform about incosistencies: Jira status vs JA process step and JA state
Nena Kruljac
is there a possibility to implement monitoring to check and inform about inconsistencies between Jira statuses and JA states and process steps?
Now I manually export JA features and Jira epics and compare it in Excel. But it would be great if it could be done automatically and send as mail once a day.
Did somebody already do it successfully?
I suppose it is possible with Adaptavist ScriptRunner script. Is there any other way?
We have implemented Jira Align process steps (mapped 1:1 in all cases except this one Jira status Canceled is mapped to JA process step Done). Multiple Jira statuses / JA process steps are mapped to 1 JA state.
Related documentation: https://confluence.atlassian.com/jakb/mapping-states-process-steps-and-statuses-between-jira-align-and-jira-software-1387599540.html
Thank you, Nena
Steve Sauser
February 26, 2025
@Nena Kruljac Thank you for the question!
This is a rather complex pattern of data flow, if the Process Steps are correctly mapped to state, the Process Steps are in an appropriate order, the Process Steps are mapped in the Project Mapping AND the Sync Process Steps with Jira States is also done correctly then this will all work.
With all that correctly set, you should have no need to compare this data to ensure things are in the appropriate states/status/process step.
You have the correct article, but if it is not working for you then there is something not set correctly, or potentially users are updating State in JA rather than the Process Step.
  • If users are updating State in JA, then this will simply be an education pattern to inform them to use the Process Step rather than State.
  • If it is not set correctly, then a more in depth review of your actual instance would be required.
If your company has an Advisory Services engagement, then we can help clear this up with you, just contact your SEM (Strategic Engagement Manager) and they can bring either an ESS and/or ETA to assist.
If your company does not have an Advisory Services engagement I would advise submitting a Support Ticket for assistance.
Upcoming Jira Align Events
