Sign up Log in
Where can i learn more about a strategic initiative in Jira Align
Deleted user April 5, 2021
Tom O'Connor
April 5, 2021
@[deleted] what specifically are you wanting to know?  The Strategic Initiative is configured on the Platform Dropdown settings and is related the Themes as a drop down setting (meta data).  https://help.jiraalign.com/hc/en-us/articles/360002757433-10X-Manage-Themes
Many of the reports in Jira Align do require the Theme to have the Strategic Initiative set.
Deleted user April 7, 2021
Thanks Tom! Just what i needed.
Hey Tom. When i go to my instance of JA, I do not see that as an option. Only one i see is Strategy. Is that because our sandbox might not be the most current view?
Like Rodrigo Cortez likes this
Tom O'Connor
April 7, 2021
Based on order of dropdown items it looks like in your instance, the Strategic Initiative field was renamed to Strategy.  Check the Platform Terminology to see if this is the case.
Shaimaa Azzam
May 19, 2024
@Tom O_Connor  Looking to know more about reports associated to "Strategic Initiative", could you please share reports? Along could you please highlight how's the following statement applies
  • "Strategic Initiative connects a theme to a strategic initiative."
Tom O'Connor
May 20, 2024
  • Technically, it is a drop-down-field which can be
  • Functionally, it can be used to categorize Theme work items. Often we see it being used to create visibility of how Themes support strategic horizons. Please find an example of how it might be used to a variation of three strategic horizons below Screenshot 2022-02-17 at 10.42.29.png
  • In regards to Reporting, the biggest value the usage of this field provides is the enrichment of Theme data in Enterprise Insights. Within Jira Align, it can be used to filter in some views like the Theme grid. Not using it will not break any major reporting within Jira Align.  Unfortunately there isn't much in the way of reporting available for this field.
  • To address the use case of categorizing Themes for enhanced visibility and reporting, there is an alternative solution within Jira Align which is called Theme Groups (). Theme Groups offer enhanced functionality both in the Roadmap view and the Worktree view while adding a little bit more complexity to Jira Align. From our experience, many customers decide to use either Theme Groups or the Strategic Initiatives field.
Wech, Jenine January 19, 2023
@Tom O_Connor  Can you tell me which reports use Strategic Initiative field?  We would like to use the field but cannot figure out how to report on it.
Tom O'Connor
May 20, 2024
@Wech, Jenine I apologize I missed your question/ask.  See above.
Upcoming Jira Align Events
