I'd like to share a useful (for me :D) feature in Atlassian Assets (part of Jira Service Management): Attribute Settings, with a special focus on Filter Objects. This is a little helper that makes capturing and managing assets easier by pre-restricting attribute values, improving data quality and reducing errors. I'll explain it step by step and provide a small example.
What Are Attribute Settings and Filter Objects?
In Atlassian Assets, you can define Object Types to represent your assets (e.g., hardware, software, or locations). Each Object Type has attributes that store data like names, references, or values. Under Attribute Settings, for reference attributes (which link to other objects), you can configure an AQL filter (Assets Query Language). The "Filter Objects" feature allows you to dynamically limit the available options based on other attributes or conditions.
This is especially helpful for hierarchical or dependent data. Instead of users choosing from thousands of objects, the system only shows relevant subsets. For more details, check the official Atlassian documentation:
Why Does Restricting Attribute Values Help?
When collecting assets (e.g., in an ITAM scenario), it can get overwhelming if users have to select from a huge list. By using Filter Objects to restrict values:
• Improved Data Integrity: Avoids incorrect assignments, e.g., by only showing matching locations for a company.
• Better User Experience: Forms are filled out faster since irrelevant options are hidden.
• Increased Efficiency: Fewer errors mean less rework in Jira issues or reports.
• Scalability: In large environments (e.g., Data Center instances), it keeps performance high by optimizing queries.
In the context of IT Service Management (ITSM), this feature enhances data quality by ensuring accurate and consistent asset information, which is crucial for reliable processes like incident resolution and change management. By preventing erroneous data entries, it supports ITSM goals of efficiency and compliance, reducing risks in IT operations.
This is especially helpful if you're not automatically populating your Assets database (e.g., via integrations, scripts, Data Manager or Discovery) – it ensures manual entries are accurate, efficient, and less prone to mistakes.
Seems helpful for me when you are dealing with complex asset structures.
A Small Practical Example: Restricting Locations Based on Company
We using the template from Atlassian and add the object types Company and Location.
You want to ensure that when creating a new "Device" object, only locations from the selected company are shown.
Configuration Steps:
Using
"Company" = ${Company}
Fill it with sample data – Here mine.
3 companies with 3 locations each
Example in Action:
In this example, we prevent a Laptop from being wrongly assigned to an incorrect location with just a few simple clicks
I hope this article helps someone save time and effort.
Have a great time exploring Assets!
Kai Krause
Senior Technical Consultant
VI2VA
Brunswick
52 accepted answers
2 comments
