Sign up Log in
How to obtain newly created Assets object in the automation rule
When you create a new issue in the automation rule, there's smart value {{createdIssue}}, which can be used further in the rule. But when you create Assets object, there's no smart value for a newly created object. What can be done?
Let's assume you've got service management project prepared for your HR department. One of the requests is called Employee onboarding and the form contains these fields:
  • What is the employee name? (Summary)
  • What date does the employee start? (Start date)
  • What is the employee e-mail? (Employee e-mail)
  • Where is the employee located? (Employee location)
After the form is submitted, your HR department starts to work on different things for the newcomer.
As a one of the steps (for example after the issue is resolved, i.e. transitioned to Done) you want to add this employee to Assets, where you have database of your employees (which means you have created appropriate object scheme called HR and object type called Employee in it).
Let's create the automation rule.
First step will be to create an Employee object - for this Create object action can be used like this (trigger issue data are used):
Now what we would like to do is to store the newly created object to the issue, so that we have all issues connected to the Employee object visible in the Linked issues section in the object's detail. For this we've prepared custom field Employee with simple configuration:
Because there's no smart value for a newly created object, we use Lookup objects action - we search for a newly created object in the database. If the object has some unique value (in our case e-mail), the result will be only one. So, in our situation we will use query:
objectType = Employee AND "E-mail" = {{triggerIssue.Employee e-mail}}
The last step is to store the found Assets object in the custom field:
Summary
If the object, which you have created in the automation rule, is somehow unique (one attribute or combination of more attributes), you can search for this object using Lookup objects action and use the smart value {{lookupObjects}} from the result.
4 comments
Tomislav Tobijas _Koios_
May 16, 2023
Cool article 🙂 Thanks for sharing!
David Foote
This solved a problem I was having with creating and immediately linking an Asset to a card - thanks for sharing!
Ingrid Heitmann October 23, 2024
Hi @Hana Kučerová and thanks for this article. Could you please expand/explain how I can get "hold of" key for a newly created object, using trigger Object created, when these objects are not linked to a ticket?
My challenge is within this scope:
Object type Organisation - objects created through CSV import.
Object type Details - is stored in another object schema, with an attribute being Organisation
  • Organisation is kept up to date through CSV imports. When importing, "decommisioned" Organisations are a archived and new ones created. This import works fine. Sometimes 1 new object is created, other times more than 1
  • I now want to expand the setup, so that when an Organisation object is created, another object in another object type to be created and linked to this newly created
  • Each Organisation object is unique, but during the automation run, I do not know what the unique object attributes are. In other words, I do not know what unique characteristics I can link the lookup to
Do you have any idea as to what my lookup query can look like?
Hana Kučerová
October 25, 2024
Hi @Ingrid Heitmann ,
I believe you can create an automation rule like this:
  1. When: Object created (from your object scheme with Organisation object type)
  2. If: Object matches AQL: objectType = "Organisation"
  3. Then: Create object ....
Upcoming Jira Service Management Events
