The analogy between ITSM without Asset Management and driving a car without a speedometer is the most accurate that appear in my mind. Both situations describe a state where important control instruments are missing that are essential for safe and efficient navigation.
ITSM without Assets is like driving a car without a speedometer
The importance of the speedometer when driving
A speedometer is more than just a measuring device – it is a critical control instrument that enables the driver to:
Without a speedometer, you are literally driving "blind" and risk not only fines, but also the safety of everyone involved. Driving without it, could be fun, but its not safety.
ITSM without Asset Management: A similar dilemma
What is IT Asset Management (ITAM)?
ITAM encompasses the systematic management of all IT assets throughout their entire lifecycle:
Learn more about building an object schema for IT Asset Management (ITAM) in Atlassian's official documentation.
The consequences of missing asset transparency
Without a solid ITAM foundation, ITSM operates practically in blind flight:
The synergy between ITSM and ITAM
Why both disciplines belong together
While ITAM focuses on the assets themselves – their management and optimization throughout the entire lifecycle –, ITSM focuses on the services that use these assets for value creation. This areas are strong connected.
Best practices for integration
You can create Assets object custom fields to better track and manage your IT assets within Jira Service Management. Assets provides a good starting template to do it.
Leverage automation for Assets objects to streamline your asset management processes and reduce manual work.
For advanced automation scenarios, you can update Assets custom fields via automation rules and even send webhooks using Assets object data.
Conclusion: Navigation with all instruments
Just as a driver without a speedometer loses control over their vehicle, an IT organization without Asset Management loses control over its infrastructure. ITSM without ITAM is not only inefficient – it is risky.
The integration of both disciplines creates a solid foundation for:
In today's complex IT landscape, it is irresponsible to operate without these fundamental control instruments. Anyone who operates ITSM without Asset Management is not only driving without a speedometer – they are driving often blindfolded.
Getting started with Atlassian Assets
If you're ready to implement proper IT Asset Management, Atlassian Assets provides a comprehensive solution that integrates seamlessly with Jira Service Management. Start by:
Remember: Just as you wouldn't drive without a speedometer, don't manage IT services without proper asset visibility. Atlassain provides a complete package buildin to drive .
Kai Krause
Senior Technical Consultant
VI2VA
Brunswick
52 accepted answers
2 comments
