JSM Approvals by Email (with a work around)
One of my favorite (if not THE favorite) features that Atlassian has recently rolled out is the ability to do Approvals by Email within Jira Service Management (JSM). This was in response to a long outstanding feature request with many votes by users. The idea is that a JSM project workflow can trigger an email to be sent to Approvers on a ticket. This trigger typically occurs when the ticket moves into a status with a preconfigured Approval process attached to it.
In our simple JSM workflow above, the Approval is configured for the In Progress status. Meaning that when a ticket moves into that status, the JSM project will use the built in process to email the Approvers asking for an Approval to the ticket.
The new functionality now allows a project administrator to configure the JSM project to use one of a few security methods when the email is sent. My preference is the no need to sign in one. This means that the Approver will receive an email with just two choices – Approve or Decline.
The recipient of the email simply clicks on the Approve or Decline button in the email and the ticket transitions automatically to the status mapped in the workflow. In my example workflow above, Approve will result in the ticket moving to Done while Decline will cause the ticket to get Discarded.
With my security setting of no sign in, the ticket is automatically moved with no sign in to Jira required! This is great for Approvals needed by Senior Leadership, who might rarely sign into Jira or be familiar with moving around inside of tickets.
As mentioned in regards to the security settings (sign in required versus not required, etc.), you can see more guidance here: https://support.atlassian.com/jira-service-management-cloud/docs/manage-settings-for-approval-by-email/
Now that’s all well and dandy, but some folks are having a slight struggle. I can’t actually modify the email text that is sent to include custom field information. So, can I really make a decision to approve the ticket by email without knowing key information about the request?
Most of us probably fall in that category. And, thankfully, there is an open request in the JAC to have the “Ability To Add Custom Field Values to Service Desk Notification Template”. Here is the link for more information (and you can vote!): https://jira.atlassian.com/browse/JSDCLOUD-4642
Until a fix is provided, what can I do? Well, here is a work around that I have used while waiting for the initial Approval by Email option to become a reality. This process is produced by using Automation For Jira.
First is an Automation rule created based on the ticket transition from one status to another. Another rule I use is based on a new ticket created in the JSM project. So there is flexibility in the actual rule trigger. The full rule looks like this:
One of the drivers of using this approach is that I can include custom fields in my email body along with HTML code to produce the Approve and Decline buttons.
Here is the actual code/text in one of the emails I send:
{{issue.reporter.displayName}} has raised an issue.
<a href="{{issue.toUrl}}">{{issue.summary}}</a>
Additional Details: {{issue.description}}
<table bgcolor="#ffffff" border="0" cellspacing="0" cellpadding="0">
<tr>
<td height="21" align="center" bgcolor="#068000" style="-webkit-border-radius: 3px; -moz-border-radius: 3px; border-radius: 3px;"><a href="mailto:jira@yourdomain.atlassian.net?subject=Re: {{issue.key}} Issue&body=I approve this ticket" target="_blank" style="font-size: 18px; font-family: Arial, sans-serif; color: #ffffff; text-decoration: none; -webkit-border-radius: 3px; -moz-border-radius: 3px; border-radius: 3px; padding: 10px 25px; border: 1px solid #068000; display: inline-block;"><!--[if mso]>&nbsp;&nbsp;<![endif]-->Approve<!--[if mso]>&nbsp;&nbsp;<![endif]--></a></td>
<td align="right" style="padding-left: 5px; padding-right: 5px;"></td>
<td height="21" align="center" bgcolor="#FD1B00" style="-webkit-border-radius: 3px; -moz-border-radius: 3px; border-radius: 3px;"><a href="mailto:jira@youdromain.atlassian.net?subject=Re: {{issue.key}} Issue&body=I decline to approve" target="_blank" style="font-size: 18px; font-family: Arial, sans-serif; color: #ffffff; text-decoration: none; -webkit-border-radius: 3px; -moz-border-radius: 3px; border-radius: 3px; padding: 10px 25px; border: 1px solid #FD1B00; display: inline-block;"><!--[if mso]>&nbsp;&nbsp;<![endif]-->Decline<!--[if mso]>&nbsp;&nbsp;<![endif]--></a></td>
</tr>
</table>
Be sure to change the yourdomain to your actual value.
Feel free to modify as you desire. This will produce an email similar to the built in JSM one above, but it includes some additional text and fields that I want to convey to the receiver of the email.
Finally, a second rule is created to cause the ticket to transition as an Approval when the user clicks on the Approve button in the email. Before I post that, I must include a VERY IMPORTANT NOTE. When the user clicks on the Approve (or Decline) button in the email, it will actually open a response email. The user at this point simply clicks send. Another caveat is that this this the process uses MS Outlook – I have not tried it with email tools such as GMAIL, Yahoo, etc.
You will also notice that the response email simply has a line that reads “I approve this ticket”. Again, the user should simply click Send and not change the text of the email. You can change that text to be whatever you like in the original email – notice in my sample code above where those words "I approve this ticket" are included and simply replace with your own wording.
The sending of the email will cause a comment to be added to the ticket as is normal Jira practice if you reply to an email sent from Jira.
Here’s the final Automation rule:
This rule will trigger when a comment is added to the ticket. We just saw above that the send of the response email will cause this comment to be added.
The If: matches condition checks for those key words associated with the Approve button of the email. When it sees those, it executes the action of an Approve of the request (an Automation new action option).
The result? The card is Approved in the system!
A final note -  I have created different rules for each JSM project to give maximum flexibility to my email text as well as reducing the number of multiple project or global Automation rule executions that take place in order to not exceed your allotment of executions for the month. It’s a simple and quick process to create the initial two rules and then copy and change for additional projects.
So let’s recap that last part in simple terms, assuming your Automation rules are in place.
  1. Some type of trigger will happen to cause your rule to be executed.
  2. The result will be that an email is sent to the Approvers on the ticket
  3. The user receiving the email will click on the Approve or Decline button, which will open a response email.
  4. The user simply clicks Send.
Please feel free to suggest changes to this process or post other solutions you may have used. My hope is that this helps make you and your team/organization a little more productive!
25 comments
Fabian Lim
December 20, 2021
Great article.  Thanks for all the details.
Like John Funk likes this
Stephan Thiele
May 5, 2022
It is an very good article and helpful, but i have a question about the mail adress in the body -->
i think this is an example mail, which particular mail adress do i have to insert here ?
John Funk
June 1, 2022
Hi Stephan - yes that should be more generic @yourdomain.atlassian.net where you replace with your own specific domain name. I have edited your message to remove the proprietary name.
Let me know how it works for you!
Like Jessica Munoz Valerio likes this
Manas Bagde August 3, 2022
@John Funk This is great. I have used it with schedule trigger to send 1st and 2nd level escalation emails. Working fine for me.
Thanks.
Like # people like this
@John Funk is there a way to add email body text in multi color? Tried multiple things but href="mailto is not accepting html tags within the double quotes.
Ex: body=I approve this ticket (DO NOT CHANGE THIS TEXT)
I would like to add (DO NOT CHANGE THIS TEXT) text in RED color
John Funk
August 3, 2022
Hi @Manas Bagde  - I am not an HTML expert, so I am afraid I would not be much help there. Maybe try some other sources with those skills?
Like Manas Bagde likes this
Chris Lynch
I believe this is a better approach for including custom fields as you still use the Approvals notification which includes the buttons.
My work around for this is as follows.
  1. Create a new Custom Field for Description. Set it render to Wiki Style
  2. Add this to the Request and Issue View of you Change Requests
  3. Remove the System Description
  4. Using Jira Automation populate the System Description with all the fields you need to include in the Email.
    1. For Example, I'm populating with custom Versions, Affected  Services, Start Time, etc.
      {{issue.Custom Field}}
  5. In the Default Customer Notifications
    1. Update the Approval Email to include ${issue.description}
Now when Approval is required I can include all information I need and adjust the information set in the System Description based on any other information. Software change would include different information to Infrastructure or Environment change requests..
If needed you can export all your issues, and import again to update the new Description field with information from the System Description before you enable the new Automatation.
Boris Berenberg - Modus Create
We recently added support for Jira Service Management approvals in Notification Assistant for Jira where we also support full customization of the email template. If you have any questions, feel free to open a support ticket at https://atlasauthority.atlassian.net/servicedesk/customer/portal/1/group/1/create/1
Ali Aydın
@John Funk
I implemented the solution, but when I send approval, Ali Aydın
Ali Aydın (No Response) I am getting No Response error and the transaction is not executed.
Can you assist?
John Funk
December 28, 2022
@Ali Aydın - Your screenshot says the Status approved
Ali Aydın
Hi @John Funk
"Approved" not set ,When I check I see that it is waiting for pending.
Regards
John Funk
May 17, 2023
@Ali Aydın - Did your automation rule fire? And if so, what did the Audit Log say?
Vinci Louise Morales August 30, 2023
is it possible to edit the color of the approval button sent in the email?
Gene Sullivant
@John Funk
We love your solution and have used if for almost a year. We used Comments as the trigger for the Replies which works but with the restrictive Automation counts coming in to play we have to make a change. I am suggesting to my Mgr we use the Transition solution.
Are there any other Triggers that would be useful? Are there any Triggers in development that might allow us to be specific i.e. "I approve this MSR" vs Comment as a main action?
Jessica Munoz Valerio January 29, 2024
Hello guys,
Thank you for this solutions John's solutions seem to work great. However, I am facing a problem when I want to add more to the "Additional Details" I would like to include more Custom fields that I created when people submit a ticket.
Example:
Additional Details: {{issue.description}} I want to add {{issue. Software Request}} or {{issue.Software Cost}}
Any suggestions on how I can do this?
@John Funk @Chris Lynch
Thank you In advance guys
John Funk
February 7, 2024
Hi @Jessica Munoz Valerio  - Do it just like you have it. Assuming Software Request and Software Cost are the exact names of the fields.
Jesse Ortega Jr
Thank You!!!
Ilya Checheneu September 25, 2024
Amazing, thank you very much for putting this all together. This automation will indulge a lot of executives!
John Funk
September 28, 2024
@Jesse Ortega Jr  - You are welcome! thanks for the Like
Like Ashok Shembde likes this
John Funk
September 28, 2024
Thanks @Ilya Checheneu  - I hope it does indeed help!
Suzi Firth
December 14, 2024
You are my hero! This worked an absolute treat!
I can't believe this still isn't standard functionality in Jira but I'll take the workaround.
John Funk
December 15, 2024
Haha - You are too kind. And I don't think you will see this come to Jira anytime soon. Atlassian likes to get functionalities separate between JSM and Jira for whatever reason. Glad it is helpful!
John Izquierdo
I implemented this method as well for one of our teams but something recently started happening where when the approver replies it will add the reply to the request and transition it like normal but it will also create a new ticket.
I reached out to Atlassian support and they've told me that if the customer isn't in "Request participant" or the "Reporter" then they cannot add a comment unless we have the option "Yes, allow all emails that contain a valid issue key to be added as a comment to the issue" toggled on (screenshot below of our current setting).
Is this correct? I thought approvers can comment on issues.
p.s. I did notice in our mail filter that the approver sent the email reply twice but I don't know why that would cause a new ticket to be created rather than two comments to be added.
John Funk
March 2, 2025
Hi @John Izquierdo  - this certainly sounds like something new that Atlassian has added. So if your Approver is a Customer but not the Reporter or in the Request Participant field, I guess you need to click that on. The other thing to try is to simply add the Approver to the Request Participant field before sending the email.
Like John Izquierdo likes this
John Izquierdo
Thanks @John Funk
I think I'll have to turn on that option instead cause the project lead would rather not have the approve in the request participant since that would include them in any reply to customer messages.
My worry about turning that I don't see anywhere (unless I'm missing it) that says the key would have to be in the subject of the email. If it's "anywhere" in the email (subject or body) that does worry me a bit. Maybe pointless worrying though but I digress...
Thanks again for your reply and help!
