Couldn't seem to find what I am looking for so asking the community.
I have a automation task that when a Task is moved it will automatically send a email out to our field technicians.
I want to include two custom field I have in the body.
Site Latitude and Site Longitude so I tried {{site.latitude}} and {{site.longitude}} but that doesn't return anything.
Great that you resolved your own ask. Since you are referring to custom fields, you can also use the following syntax in the issue smart value syntax -
{{issue.fields.customfield_xxxxx}} where xxxxx is the actual internal field ID.
You can use the above format instead of using the actual field name.
Hope this also helps.
Best, Joseph Chung Yin
How do I find the custom field ID? When I go to the fields section I don't see everything I saw when browsing through the community available to me.
I answered my own question.
Instead of using {{issue.site.latitude}} just used {{issue. Site Latitude}}
