Adding field on project level
erika
Is there way to create a field that is on a project level in Jira next gen rather than on a ticket level? We should be able to export this field as part of the ticket export as an example.
thanks
Erika
Leo Diaz - Deiser
Hi @erika
I'm Leo, Head of Product from DEISER (Solution and Marketplace Partner)
You can use Profields:
https://marketplace.atlassian.com/apps/1210816/profields-jira-project-tracking?hosting=cloud&tab=overview
At the moment it is not possible to see the value in the issues but you can raise a ticket with the suggestion so we can prioritise it:
https://jira.deiser.com/plugins/servlet/desk/portal/1/create/111
Hope it helps!
Leo
