Sign up Log in
Asset attribute not being returned when linked to Custom field in JSM form
Justine Lions
Hi - our Sandbox was rebuilt when a 3rd party was upgrading our JSM/Jira ITSM setup. It was a fast export/import and not fully tested and I've been aware for a while some things are not set up correctly but we had no time at the time to fix it. I suspect this is one of the things that has been busted for a while - although thankfully its happily working in production. But now I have to upgrade this form with this custom field and I would like to understand why its broken and fix it so we can properly test this form. (And I avoid introduce anything wrong into production by ignorance)
The form has a field labelled 'Name' linked to a global custom field Signature with object type Asset Object/s.
A user is expected to type their name in this field and the only name they should be able to type is their own. However the only response given is 'No options' to any interaction even selection.
The custom field's object configuration is:
Object schema: People
Filter scope (AQL): objectType= People
Filter issue scope (AQL): User == currentReporter()
Allow search filtering by these attributes: Name
Object attributes to display on issue view: Name
Field can store multiple objects: No
Display a default object when this field appears in a customer portal: No
Object attributes and type values are what you expect (subset shown).  Type is all default
Attributes
Key Text
Name Text
Created DateTime
Updated DateTime
Employee ID Text
User Text
Email Text
UPN Text
Job Title Text
Manager Text
This all matches in production.
One thing I did notice this morning is that the attribute ID numbers are different - I am assuming this is like the Custom field IDs can be different and I just have to make sure they align. I do not quite understand the response ChatGpt has given me to try to understand the issue as it seems to be everything that is already in the help files. Would appreciate any other suggestions of things to try.
Sarah Wright
Hello there,
Please give this video by Jimi Wickman a look as I think you'll get a better understanding of how this works and ideas how to set up your field.
I see that User is a text field. Assuming your customers are all users, create a new attribute of type User and populate the users. Then you can use the AQL "new attribute label" = ${reporter.label} This should allow the reporter to select their name. They won't be limited to typing anything, but should be limited in what they can select. And of course make sure all your AQL matches assets exactly. Caps, spaces, etc.
Hope this helps!
