Assets Imports - Filter on Assets data
Johannes Nyberg
Hi
I am aware of the possibility of filtering the data source by AQL. But I am interested in filtering my already published data in Assets.
An example
- I have an csv-file containing a lot of "sites" I want to continuosly update these "sites" with new imports until the "site" is marked with a status "inactive". This is a manual process and when this is done I dont want to continue to update the object even though my import data for the site exists.
See image below, I understand that this focuses on the import data not the already existing data.
Thank you,
Johannes
Kris Dewachter
Hi @Johannes Nyberg ,
I don't think you can do that with the csv import. If you supply the asset in the csv file, it will be updated. Unless you filter it out with the AQL like you already mentioned.
Best regards,
Kris
Johannes Nyberg
Can I do it with any other kind of import structure? Such as JSON?
Best regards,
Johannes Nyberg
Kris Dewachter
I don't think so. JSON works in the same way as csv.
Best regards,
Kris
