Assets automation smart value for linked objects inbound references
Iman Attia
May 22, 2024 edited
We are trying to use the smart value:
{{lookupObjects.(reference name).(attribute name)}}
The lookup object returning is correct, printing in the table but no luck on getting the InR name/labels to print.
|| Name || Components ||
{{#lookupObjects}}
|{{Name}}| {{Component.Software Component}} |
In this case:
Objects inbound ref Type: "Component" - This is NOT an attribute name on the object.
Label / name for InR name "Software Component"
I've tried:
{{lookupObject.Component.label}} OR {{{{lookupObject.Component.Software Component}}}}
Any way of referencing the inbound objects without another lookup?
Daniel Vest May 28, 2024 edited
@Iman Attia
 I am very new to this idea of pulling info from Assets into tickets and automations. What may help you is to see what I learned & did in my test area just the other day. I was trying to find the asset number of a laptop assigned to a person (who is listed as an Object in the Assets area) and is an Inbound Reference.
  1. Inside of my Asset area I have my Test Person in one Schema
  2. And my laptop in another section of another schemalaptop object.PNG I created a custom field that could look at the Objects and filter right to the AQL and be seen/stored
  3. Created an automation rule to find the asset object linked to the user based on the respective fields/objecttypeID
      1. object having outR(ObjectTypeId = 331 AND "User Jira" = {{reporter.accountID}})
      2. {{lookupObjects}}
      3. {{lookupObjects.Name}}
It is not exactly the same thing, but it may help you achieve what you need to, hopefully
Iman Attia
I'm trying to pull the inbound ref > Component "Vulnerability Manager"
Neha Mahajan
January 14, 2025
Hey @Iman Attia  Here's a FR for this, currently with the lookupObjects smart value, it isn't possible to fetch the inbound reference:
JSDCLOUD-14321 - Asset - Using smartvalue, fetch attribute information of inbound references
See if it helps.
