×We have an automation that auto links issues based on comments made. It checks if if the format of what has been commented matches our ID formatting.
Then links the issue(s)
Now this works fine, but it tries to link anything that matches. Which causes multiple daily errors. Is there a clause I can put in to check if the "A-Z" part matches our IDs?
I have though about adding in the below before the Link Issues, but I have no idea if that would work. Or if theres just a better way to do it.
Hi @Terry Dance
Hope you are doing fine.
You may consider using below syntax for the REGEX:
^.*DEF.*$
Hope this helps.
Regards.
